sway bar extension kit
Grapevine, Texas
do i need a sway bar extension kit with a OME lift, or can i just use the factory set up with new bushings? its a 83 fj 60.
the OME lift should some with them.. and my belief is yes. I put the on OME seutp with 1" extended anti-inversion shackles. Once I upgraded the front swaybar links my handling was increased dramatically.
Dont forget pics!
My OME kit didn't come with extensions. I bought them from man-a-fre. You don't NEED them, but with a 3" lift, the sway bar tends to sit funny unless you have the extensions.
You can actually build them yourself if you can get down to the local hardware store...
ditto
That's what I did and it worked out very well!
The MAF ones are just a length of all thread with a tube slid over it. They are cheap from MAF already but seriously, it would cost like 5 bucks at the hardware store. Anyone know where to find extensions for the back?
