while swapping out sway bar bushings, a bolt decided it couldn't hang on any longer and is no stuck in my frame. PB blaster is on it now but vice grips and channel locks are not turning it. Is the only option to drill it out?
Just use high quality metal bits, shouldn't really matter what type. Plenty of cutting oil. Toyota bolts are pretty easy to drill through... unless you break a bit off in them
And it is totally drill-outable. Just drill out the center, use an extractor bit and it should come out. I had one break off on me in the same place and used the above method when I was replacing my TBs. the above method would work, I just prefer keeping it original.
Would an angle drill fit? Maybe tool loaner program or a cheap Harbor Freight job.I have a decent angle on it with the TB in, but it's not 100% straight on
Yes.Did you replace it when the TB was out? The problem is, you can't get to it on center with a drill bit with the TB in place.
X2 on thisYou don't need to remove the torsion bar.
The part sticking out is not where the threads are, they are in a welded-on nut on the top of the frame.
You can't drill it out, the threads aren't anywhere near the bottom, you will just be wasting your time. Probably not going to get anywhere with vice grips either, since the exposed threads are rusted away. This bolt almost always rusts to junk because the AC drain drips on it.
Take a hard chisel (NOT a wood chisel - use a hardened one made for metal). Knock the welded-on nut off the TOP of the frame. Stick a little mirror up there and you will see what you have to do. A couple whacks with a big hammer and it will let go, it is just tack welded on. Then replace with a new lock nut.
Trust me, this is the easiest way. Literally a 5 minute fix.
