- Year
- 2005
- Vehicle Model
- LX470
- Mileage
- 29700
- Color
- black
For sale my 2005 LX with 297893 will go up still daily driving it. $9K
Currently leasing 2019 Taco trd and at this moment most likely i will keep it and will pour money in to it instead another 10k in LX,
Bought it from mud link SOLD - 2005 LX Baja Truck $5000 - https://forum.ih8mud.com/threads/2005-lx-baja-truck-5000.1193451/#post-12917958
When i got it it had leak from power steering hose by the reservoir and small coolant leak, I thought it was water pump
but it was thermostat housing.
Drives straight and smooth, no weird noises, AHC works fine currently have 9-10 graduations front press 6.3,rear 6.0
Brake booster build pressure in 28-29 sec. contacts are clean.
Everything works even the original power antenna ,passenger front door lock sometimes will not lock with remote.
Pinstripes ,few dents here and there.
Rear right taillight could be replaced, as is it doesn't bother me.
Interior is not spotless ,seats could be redone.
No engine skid plate ,throw it away because i was going to order slee .Few bolts broke and need to be extracted.
Clunk coming from the front left corner, my suspect is LCA bushing only audible when driving off-road ,not audible on the street.
Missing passenger armrest and that that is all i can think of as a "bad" stuff
Surface rust on the frame no rust holes anywhere.
And every car/truck add need this line "Ill drive it anywhere right now" but really i would take it anywhere, it is a solid base for trendy overland/trail/camping rig project.
Priced at 10K,just wanna take what i have in it and this is my bottom price.
Come look at it test drive it or take to your mechanic .If u need pictures of specific parts let me know. AHC set to HI on pix.
Send me your email for Carfax pdf, clean title.
Below is the list of parts installed during timing belt job 296125.
Amazon
Cardone Service Plus 3R-108 New Power Steering Reservoir $78
TOYOTA Genuine V Ribbed Belt Tensioner Assembly $64
AISIN FBT-002 Fan Pulley Bracket $140.26
A/C Condenser $125
AISIN TKT-021 Engine Timing Belt Kit with Water Pump $169
12204-50030, PCV Valve $13
From rock auto
DENSO 2800320 starter $128.79
DENSO 2344154 x2 o2 $95.58
DENSO 2344138 x2 o2 $75.58 not installed ,included
DENSO 6731303 x8 Ignition coil $50.79
CSF 3006 Radiator ,bought 3 picked the best looking one $122.79
DENSO 2101099 Alternator $195.89
BECK/ARNLEY 1580894 x8 Fuel Injection Nozzle O-Ring Kit
ACDELCO GF788 fuel filter
AISIN HST021 Ride Height Sensor left $161.79 not installed ,included
AISIN HST020 Ride Height Sensor right $148.79 not installed ,included
AISIN HST026 Ride Height Sensor rear $164.79
GATES K060882RPM serpentine belt $40.79
BECK/ARNLEY 1015773 rear end link x2 not installed ,included
BECK/ARNLEY 1015543 frond end link x2 not installed ,included
McGeorge
90311-38065 Camshaft Seal $16.08 2 $32.16
12262-50080 Hose Ventilation N $13.74 1 $13.74
12261-50050 Hose Ventilation N $16.16 1 $16.16
90080-91180 Spark Plug $7.76 8 $62.08
90311-A0001 Front Crank Seal $8.80 1 $8.80
90916-03100 Thermostat $19.18 1 $19.18
90915-YZZD3 Oil Filter $4.04 2 $8.08
15767-50101 Water Inlet Tube $36.19 1 $36.19
15777-50030 Return Hose $18.67 1 $18.67
16282-50040 Inlet Hose $7.05 1 $7.05
16281-0F010 By-Pass Hose $6.23 1 $6.23
16346-50010 Thermostat Gasket $4.14 1 $4.14
16401-67150 Radiator Cap $12.42 1 $12.42 not installed ,included ,csf cap currently installed
16572-50150 Lower Hose $32.90 1 $32.90
16571-50150 Upper Hose $23.15 1 $23.15
90999-92004 Vacuum Hose $10.14 1 $10.14
17341-50170 Hose Air $22.27 1 $22.27
23273-50020 Hose Fuel No.2 $26.54 1 $26.54
17030-50070 Hose Assembly Air $36.29 1 $36.29
17171-50020 Manifold Gasket $18.30 2 $36.60
17345-50080 Hose Air No.5 $15.33 1 $15.33
16261-50090 Engine Coolant Hose $5.65 1 $5.65
83520-60051 Oil Pres Sending Unit $45.69 1 $45.69
90029-07010 Nut $2.17 4 $8.68
Partsouq
2382950070 HOSE, FUEL VAPOR FEED 1 14.19$
2586050100 VALVE ASSY, VACUUM SWITCHING 1 38.41$
9046720011 CLAMP OR CLIP(FOR WATER BY-PASS HOSE NO.2) 6 1.60$
1763016040 VALVE ASSY, AIR CONTROL 1 54.24$
2227150042 GASKET, THROTTLE BODY 1 10.65$
1629550070 HOSE, WATER BY-PASS, NO.7 1 3.50$
1629650030 HOSE, WATER BY-PASS, NO.1 1 3.50$
9613551300 CLAMP OR CLIP(FOR FUEL HOSE NO.1) 10 1.44$
1632150020 INLET, WATER 1 24.59$
1717150020 GASKET, INTAKE MANIFOLD TO HEAD, NO.1 2 2 11.93$
1660450030 PULLEY SUB-ASSY, IDLER, NO.2 1 1 35.12$
9043012026 BOLT, UNION(FOR FUEL PIPE NO.2) 1 1 0.57$
2323241081 GASKET(FOR FUEL PIPE NO.2) 1 1 1.00$
2327050012 DAMPER ASSY, FUEL PRESSURE PULSATION 1 1 44.78$
2328050050 REGULATOR ASSY, FUEL PRESSURE 1 1 43.45$
2327150150 HOSE, FUEL 1 1 35.57$
5238060040 SUPPORT ASSY, DIFFERENTIAL 1 1 85.64$ not installed, included
4165460010 STOPPER, DIFFERENTIAL MOUNT, LOWER 4 4 5.52$ not installed, included
4165360020 STOPPER, FRONT DIFFERENTIAL MOUNT,UPPER 1 1 18.85$ not installed, included
5238060030 SUPPORT ASSY, FRONT DIFFERENTIAL 1 1 85.64$ not installed, included
4165360010 STOPPER, DIFFERENTIAL MOUNT, UPPER 1 1 18.85$ not installed, included
4165160010 CUSHION, FRONT DIFFERENTIAL MOUNT, NO.1 1 1 21.23$ not installed, included
9011914090 BOLT, W/WASHER 1 1 2.91$
1671150090 SHROUD, FAN 1 1 80.48$
9676135035 RING, O(FOR WATER INLET HOUSING) 1 1 1.85$
482316A730 SPRING, COIL, REAR RH 1 1 113.60$
482316A740 SPRING, COIL, REAR, RH/LH 1 1 118.43$
4342160060 FLANGE, FRONT AXLE OUTER SHAFT, RH/LH 2 1 61.86$
4342335010 CAP, FRONT AXLE HUB GREASE, RH/LH 2 2 1.88$
9017010039 NUT, HEXAGON 12 12 0.53$ not installed, included
9020110075 WASHER Toyota 12 12 0.66$ not installed, included
4232360030 WASHER, CONE(FOR FRONT AXLE SHAFTRH/LH)12 12 0.74$ not installed, included
4342260070 GASKET, FRONT AXLE OUTER SHAFT FLANGE 2 2 0.99$
4352160011 NUT, FRONT WHEEL ADJUSTING, RH/LH 4 4 3.78$ not installed, included
9021542025 WASHER, FRONT WHEEL ADJUSTING LOCK 2 2 1.31$ not installed ,included
9021442030 WASHER, CLAW (FOR FRONT AXLE HUB) 2 2 1.88$ not installed, included
9017912115 NUT, W/WASHER 4 4 1.04$
1237150180 INSULATOR, ENGINE MOUNTING, REAR NO.1 1 1 112.26$
Misc.
Metal Tech 4x4 100 Series Land Cruiser/LX470 Rear Link Bundle (upper & lower links) $674
Trail tailor 100 SERIES CREEPER SKIDPLATE $435
15 qts Toyota WS atf drain and fill
Valvoline Zerex coolant
Fresh engine oil ,air filter,Shell Rotella Gas Truck Full Synthetic
Fumoto drain valve
Owl expedition media mount
Added 2 x Gamiviti grid panels $100
"Big Three Cable Kit"from mud member ,actually big 4 replaced the stock wire from alternator to battery.
77300-53010 Toyota Fuel Tank Cap
81570-60061 GENUINE OEM LAMP ASSY third brake light
87248-60460 OEM Genuine HEATER HOSE T PIPE x2
Roof rack refreshed with Raptor 2K Black Spray-On Truck Bedliner Aerosol
Replaced steering rack bushings.
Recent alignment and wheel balance.
Repaired rear ac line with Dorman 800-673 Air Conditioning Line Splice Kit for 5/16" so far so good no leaks
AC recharged ,currently coldest temp i got was 37F from main vents on HI
Somebody buy it before i change my mind ,still on the fence.
Amazon
A/C Condenser $125
From rock auto
McGeorge
Partsouq
Misc.
Fumoto drain valve
