Sunroof stuck open - Manually close?
jeremy j
Austin
EDIT:
I was able to et it o close by disconnecting the battery for 20 minutes and then holding tilt for 15 seconds. Apparently that is a diag mode and cycles it. I am just going to leave it closed for now and not worry about it. Eventually, I'll get bored and see if it is still having issues.
I almost never use my sunroof but this morning I opened it and it opened fine. When I went to close it, it doesn't do anything. No noise no movement. I checked all fuses and tested the switches and all are fine.
I pulled the codes and have these:
B2343 Sliding Roof Position Initialization Incomplete
B2341 Sliding Roof Sensor Failure
B1273 Sliding Roof ECU Communication Stop
B15EC Backup Battery Degradation - I don't think this one is related.
Is there a way to manually close it like some other cars? I pulled the overhead console and I don't see a gear to turn like I've seen before. I am hoping one of you (@Acrad) know how to do this or have a diagram that shows it.
Good to hear you got it closed
Unfortunately.. I’m not aware of an emergency gear like I’ve also seen in other cars to close manually.
You’d probably have to drop the motor and see if you could find something to close it that way
Thanks for the reply. I figured if there was a way to close it you'd be the one to know.
That is what I was seeing too. Annoying but at least it's closed for now.
