Stuck passenger window in HJ-60
Newfoundland and Labrador, Canada
Unable to roll up my front right passenger window yesterday on my 87 HJ-60, after the first 1/3 of the way. Appears to be gear-related..because resistance is met with a solid thud.
Unfortunately, it's the weekend and can't find any mechanical help with this (travelling in Saint John, NB Canada at the moment), it's a bit of a hindrance right now.
Started to take the door apart, starting with the inside panelling (minus the roller handle), had a look at the mechanism, but with poor exposure. I have limited knowledge of this sort of thing...can anyone offer suggestions??
Thanks, and much appreciated!
Pascal
Sounds like your regulator is toast (usually happens to driver's window 1st).
There should be 3-5 bolts holding the regulator to the door panel, mostly around the handle shaft. Remove those & slide the roller through the slot in the track at the bottom of the window to remove the regulator. Cut a 2x4 or whatever you can get your hands on to jam under the window to hold it all the way up until you can get a replacement regulator.
CruiserParts should have a used regulator fairly cheap. Be sure to lube the shaft & gears with white spray grease before installing.
