Stuck in reverse gear, 5 spd manual.
Wagin, Western Australia
Hi, i am sometimes having to turn off engine and pump clutch a second time to get out of reverse gear on my 95 diesel troopy. Everything else seems fine, clutch pressure ok fluids ok etc, cant work it out and had no luck searching the forum. sorry for bieng so brief a bit busy getting ready to attend a wedding 200 miles away tomorrow and need to use the troopy, need to understand if it is ok to travel like that etc
A long as you dont use rev gear you should be good. It might be worn bits in the shifting mechanism
Is that a guarantee, the wedding is in Baldivis, ill call you for a tow if it hits the fan, ;):p haha, nah should be ok the grooms family is from Albany so plenty people heading back through my way if needed. I'll take a look at the shifter when i get back, thanks for tip. :cheers:
