Strange Headlight Setup
BROKEROB1
York, PA
Just finished with the Slee upgraded headlight wiring harness and replaced low beams with HIR's. What an enormous difference in the QUALITY of light output. Definitely one of the easiest and best "bang for buck" mods.
Anyway, upon removal of old headlights, PO had two low beam Sylvania's on left side (one in low beam outside slot and one in high beam inside slot) and two Sylvania's high beams on right side (one in low beam outside slot and one in high beam inside slot). IIRC, the left side low beams were marked 51W and the right side hi beams were marked 55W)
Do you think the PO did this by mistake or was there a reason? Would've that made a large difference on light output?
Also, when other would complain about night low beam's, I never thought it was much of an issue.
Rob
that sure seems like a mistake....cuz first of all...9006 and 9005 plugs may look similar...but they require modification to fit in the opposing slot, and secondly...using a 9005 on a 9006 unit MIGHT burn out the wiring due to the extra wattage as well as amp pull.
