Stiff front end sometimes...Globes? or something else?
99 LX 101,000 miles
I have a few strange problems with my IHC system. about 3 years ago but only 5000 miles https://forum.ih8mud.com/100-series-cruisers/392840-ahc-accumulator-old-fluid-b-b-vs-toyota.html , truck has been parked quite a bit the last 2 years, I did 4 new globes. Now the front end is stiff and bouncy again. At first I thought the globes were bad again but now I think there might be something else going on.
Symptoms
Ever since I got this truck it has felt like the suspension settings only controled the rear of the truck. Soft makes the rear way softer but the front stays about the same no matter what setting you are on. Is that normal?
Stuff front end most of the time
When I go over a speed bump in the Low height it is quite a bit softer than at N. I can't get the system up to the high setting?
Some times when I start the engine the front of the truck "falls" 1 inch then comes back up to height?
My thoughts are the torsion bars are weak and the IHC is trying to make up for it with higher than normal pressure? I don't have access the the Hyd pressure testing gear to confirm. Can I crank up the torsion bars? Air in the system? Bad globes again?
Any ideas??
Mac
99 LX 101,000 miles
Symptoms
Any ideas??
Mac
