Hi guys,
I have a 2002 LC with 145k miles on it. I had some pulsation in the brakes earlier this year and had the dealer turn the rear rotors, which helped dramatically. However, my problem seemed to persist albeit to a lesser extent. I thought the front rotors might need turned as well; however, upon closer inspection today, it appears to me that the front rotors are perfectly fine without any pad material on the rotor surface.
I also noticed the pulsation is getting worse. In fact, it's not really a pulsation but a tugging / uneven / hopping sort of feeling when applying the brakes. It feels like I am towing a trailer with independent brakes whenever I apply braking force. I started hearing a groaning / creaking when releasing the pedal coming from the rear right. Over lunch I looked back there and saw oil residue collecting on the rotor shield. Also smells like burnt oil.
My new theory is that the caliper is shot and sticking / not releasing, which causes uneven braking force that results in my symptoms. I now think the front rotors are perfectly fine.
What do you guys think? How hard is it to change a rear caliper on an LC? Is an OEM caliper the way to go or will aftermarket suffice? Should I change one or both calipers at the same time?
Thanks in advance,
NicB
Thanks in advance,
NicB
