Step By Step AHC Lift Help
I think this knucklehead of a retailer sold me the wrong springs!!!
I pulled a picture from Google.
So I finally got the rear springs in. I installed them today. A couple of pictures enclosed. The first picture is of the stock springs versus the 80 SeriesnSprings on the driver side and the second picture is of the passenger side. The 80 series springs are slightly shorter. However they are 15 mm in diameter versus the stock springs for the AHC being 12 mm, a pretty significant difference. After I installed the springs I tried to pull them out when the axelmwas fully articulated and it was impossible. In other words, the shorter height makes no difference whatsoever. There's a lot of compression on the AHC springs which the 80 series don't have to do. I know it works much better because when I put the AHC in low, the car takes quite a bit longer to lower itself and it doesn't drop the way it had been recently.
hi i have LC100 1998 and have problems with AHC,when i start my car the AHC is on Normal and after a short drive when i stop the AHC go to LOW and the vehicle drive is heavy also the AHC does more to the HIGH can someone advice what i should do to fix this problem
