Haven't seen a straight answer in my search. My steering wheel is no where near centered. Will an alignment fix this or does it need to be removed and put back on? Not much knowledge of the whole process.
Thanks!
DON'T adjust your steering wheel by removing it and repositioning it. You need to adjust your drag link. Loosen the clamps and rotate the link rod until the (steering) wheel is in its centered position. If the front wheels are off the ground it is easier to do. Follow the procedure in the FSM. Don't pay some joker to do this it is very easy and quick.
Dynosoar![]()
What he said, moving the steering wheel too much will cause the turn indicators to not function properly
