Hey guys, need some help.
I've got some play where the steering yolk #39 clamps onto the upper splines of the intermediate steering shaft #630 (just in front of the firewall). Not alot of play, but enough to make me want to take care of it.
Anyway, is there a fix other than tearing it apart? Maybe something you can pack in there like the way you use a speedy sleeve?
I've already sheared off the clamping bolt #82 trying to tighten the yolk around the shaft splines.
If it means replacing parts, would it mean dismantling the entire steering column assembly and replacing the shaft, the yolk, or both? Can you just remove the intermediate section?
Any suggestions? Thanks.
