Gretsch
I have been searching on this all day on this but have not come up with anything definitive. A few threads about replacing the prop shaft and joints, but have seen very little about maintaining it. The FSM I have does not have anything on the steering components that I could find. So at the risk of exposing my utter noob-ness, are the U-joints on the Steering prop-shaft greasable? I think I figured out there is a zerk fitting in the lower part of the shaft (covered by a heat shield) that you can hit with a grease gun, but I do not see a zerk anywhere in the upper U-joint near the firewall (still in the engine bay)that would allow me to pump grease in there. The U-joint there has what look like grease seals that would indicate its somehow greasable but I just don't see any way to get the grease in there. Perhaps I am just missing where the fitting is on the joint (trying to spin the shaft a bit at a time and look for a fitting) or maybe these have needle type fittings that is covered over with dirt or something or it can only be seen from underneath. I only had a minute or two to look last night but will have another look tonight if I can when I have more time. Perhaps there is no fitting and you need to use a syringe to inject grease in this joint? Again sorry for getting noob on everyone. As always, thanks in advance for the replies.
