Steering Issue
The Valley of The Sun, AZ
84 fj60 that is really hard to steer...stock suspension. Do i need to replace all tie rod ends or is it the steering gearbox??? she's a little sloppy runnin straight but binds up pretty bad when turning.
Sounds like a compilation of problems. If it is a bit loose driving down the road, it could be worn TREs or a sloppy box (might just need adjusting). If it seems to be taking extra effort when turning (assuming stock or close to stock tires) then the pump could be bad.
Check your steering pump to see if the fluid is burned. Try replacing fuild and greasing the t-rod ends.
