Since installing my OME shocks and UCAs, my steering is very heavy and slow to return to center. I had it aligned and this problem was worse after doing so. The les Schwab tech said my steering rack is bad. I’m not so sure.
What I’m experiencing when driving is the steering is super heavy for a few degrees of turning and then the resistance lightens for a few more degrees and then sometimes comes back a bit. It’s always slightly heavy the extent changes. Colder temps also make it worse. P/S pump seems fine.
after reading some Toyota forums, it sounds like it could be my lower steering column. Specifically, the u-joint on the steering colum just before it attaches to the rack may be seizing up. I sprayed some penetrating oil on the u-joint, hoping this will lube the bearings and it seems slightly improved.
Am I on the right track? Is there a good way to know whether this is a rack or column problem before I go spending hours and $$$ on parts that may be fine?
A new rack from Mr T is around $600 and a solid Saturday for me. A column is $250 and a couple of hours.
This is on an ‘05 with 200k miles.
