G'Day folk,
I've searched for other people who have had a Steering Column Tilt Motor fail on a Lexus LX470 (mine is a 1998, 110,000 Km). Plenty of people have had failures of the tilt motor on other Lexus vehicles, but not many on the LX470. I only found one! The design in the LX470 is quite different to other Lexus'.
Anyway, mine failed some time ago, but the telescoping motor still works fine, and the steering column tilt was in a safe position to drive, so I have left it until now. I pulled the motor out during the weekend and found that I could not turn the motor by hand, even though it is a direct drive with no gearing at all. Suspicious and curious I pulled the motor apart and I can see why the motor is impossible to turn. A very strong concave disc spring pushes rotating and non-rotating parts together very firmly. In fact a disc with a ring on it like mylar contacts a set of fingers attached to the body. Frankly I can't see how this motor would ever have worked, but it did. It uses induction or something, and has no brushes. It must produced quite a bit of torque to overcome the friction designed into it! Actually I'm a bit suspicious that my Lexus dealer may have pulled the motor apart and put it back together wrong, but I can't really work out a better assembly sequence that wouldn't cause the friction between parts. The bearig is fine, and the whole motor is quite a highly engineered unit, with very accurate machining tolerances. It looks like the motor could be reconditioned, but I can't find any information on it let alone parts breakdowns or spare parts lists!
I had a quote of AU$470 from Lexus Australia sometime ago for a replacement motor. I have now found out that it is the same motor as used in the Landcruiser, so I can use the cheaper Toyota part at AU$321.20.
The part number is Toyota 89231-60010, Denso 110750-0011 7T.
Anyone else has had such a failure, and if so, was the electric tilt motor is repairable? How much did it cost you, and when did you have it done?
PS: Yes, I could just put the motor back in with a better tilt position, but I like the automatic tilt and telescoping of the steering column, and I want it back!
Not as well as the new one, but it did rotate three full turns in each direction, the same as the new one.
