So, as part of the ongoing saga in keeping my truck in reasonable condition, I have been collecting parts to replace the deteriorating body.
I picked up two fenders several years ago from Crushers that needed some patching, and cut my teeth with my HH140 welder repairing some rust spots. I also got two doors from a mud member in Idaho that just needed some heavy sanding to be ready for paint. I did need to weld in a washer on each door where the bolt that holds the window track had pulled through.
Anyhow, I had planned to spray the paint with a siphon feed gun I have had for years, but when I dug it out the needle was stuck and after cleaning old paint/gunk off it the seals must be shot because air bleeds out everywhere when hooked up to the compressor.
My plan-B was to buy a new gravity feed gun, but then I remembered an old HVLP system I bought years ago to spray doors and trims in basement renovations I was doing for a living.
I dug it out last night and shot a coat of paint on one of the doors.
It did a decent job, but I had to lay it on bit thicker than I would have liked to get it to self level. The gun doesn't seem to atomize the paint enough. I will need to play with the adjustments I guess. After I learn a bit more about spray guns.
Here are pics of the HVLP system, the paint and the door.
