Well, at amongmany, what is it you want to do? Is it a small group, large group wandering by your self? Will you be close to the cellular towers, total off grid? Short trips or long treks across country.
You should get whatever everybody on your group uses. If they use CB, get a CB. If they use FRS, get an FRS. If they use MARS, get a MARS. If they use GMRS, get a GMRS (and the license, not test required). If they use ham, get a ham radio, take the test.
I have cb, gmrs, and ham (the first test - Tech- isn't that difficult).No license needed for FRS. A license is needed for GMRS. You'll get a FCC call sign assigned. No test just pay the fee. It's $70 for 10 years.
Thanks for the input folks. I don't "run with a group" yet as I'm still getting myself sorted and getting the minimum gear necessary. Hence, no idea what "they" use. Most of the group runs I've seen require that you bring some sort of comms device, so it's a chicken/egg predicament at that point.
I may also be traveling alone a decent bit, so something with more reach wouldn't be a terrible idea.
If you’re traveling alone in very remote areas your most reliable method by far is via satellite using a device such as Garmin Inreach etc. The next best method is a ham setup with knowledge of how to interact with a repeater.
I’ve had really good luck with the Inreach mini. It connects to the phone app via Bluetooth which makes it easier to send messages etc. I also like that while it does require a subscription you can easily turn the subscription off for when you’re not planning on needing it.
For group com just pick up a $25 uv5r for ham and an inexpensive gmrs. CB is used less and less and sucks compared to the other options.
Realize that you legally need a Amateur radio license to transmit on 2m and 70cm bands withe the Baofeng. Although the Baofeng can be re-programmed to work on GMRS, MARS and FRS frequencies, they cannot legally transmit on those bands.
Having said that, even though I have radios that work on most bands, I have found my FRS and GMRS radios the most useful for my overlanding trips. FRS radios are so cheap and license-free that I carry four of them and just loan them to people in the group who don't have one. Consider just starting with FRS and see if most of you comm needs will be covered before buying a Baofeng and getting a ham license.
