2005 LX470, 113k on the odo
Bought it with 107k, had a bad front wheel bearing at that point, new front pads & rotors, ran snow tires all winter and had a strange harmonic noise that didn't go away when I swapped to new Hankook Dynapro AT/Ms in April, so I took it in to my nearest shop. Figured it was a driveshaft U-joint......it would appear above 65mph, on the throttle. If you lifted, the noise went away for a second or two, until the driveline caught back up......if you shifted to Neutral, it went away instantly.
Local shop (Chrysler dealer, only place I've got within 50 miles, I've known the SA for 20 years) sent the driveshaft in, had it balanced, 2 new joints installed on it, and handed me the keys last night, told me it was good to go.
Well, THAT noise is gone, but now I've got something else. Keep in mind, vehicle has been sitting in their parking lot for 2 weeks while they sent the driveshaft off to be serviced by a place that is well-known in this area for their driveshaft work.
So now, at any speed above 50-ish, I start to feel a vibration in the floor.....in the seat......(not so much in the steering wheel). By 70, it's starting to cause the loose change in the cupholder to buzz........by 75, it's even worse. Let off the gas, and it's definitely there. Shift to Neutral, it doesn't go away. Turn left and right (as much as you can at speed) and don't see any noticable change.
Where-as the Driveshaft U-joint issue was a definite Harmonic/Audible thing that went away instantly when you took the load off the drivetrain, this is a vibration/grumble that doesn't go away.
1) I'm thinking wheel bearing. Either the other front wheel bearing, or perhaps a rear. None other than the RF has ever been replaced. My RF wheel bearing failure made no noise.
2) Sticking brake caliper, causing warped rotor/engagement going down the road.
3) Perhaps (much less likely) some sort of tire balancing issue, but these tires were smooth as silk up to 75mph before I took it to the shop
So I took it back this AM and had the Service Adviser ride with me. He thought possibly a Carrier Bearing going bad, but wants to put it on the hoist and check before he made an actual recommendation, says it SOUNDS like a bearing.......carrier bearing seems like a grasp in the dark, and $$$ too. I just searched the board, and don't see many (almost none) stories of 100 series Carrier Bearings wearing out at this young of mileage.
***So why all of a sudden? Is the shop to blame (ie something related to driveshaft repair)? Was the bad U-joint masking this, did it happen because it sat for 2 weeks, or is it simply bad timing?***
Any and all help is appreciated.
Thanks, Ben
Thanks, Ben
