I'm looking for help diagnosing the most likely problem and / or how to isolate which problem is the most likely.
I know I've got at least a small leak around the power steering unit - not huge, but some seepage that I'll only better understand over time now that I've cleaned up the existing sludge. In addition, I just had the serpentine belts replaced as the previous belts were dry and cracking.
Now... only occasionally, and it seems only when I do sharp turns, like 3-point turns in a parking lot (though even then only 1 out of 10 attempts), I get a squeal or squeaking noise from somewhere in the engine bay. Because it is so intermittent, I have not been able to reproduce it on command or with the hood open and an assistant present so I can better isolate where the sound is coming from. The pitch and tone of the sound is somewhere in between the chirp or squeak of a belt slipping or a high pitched groan of a bearing or hydraulic pump under duress. So... I could be dealing with the belt crossing the power steering pump with improper tension so it's slipping when the power steering unit is under high load, a bad bearing somewhere along that same belt path that is feeling the strain under load, or the power steering unit itself is struggling.
Any ideas how best to most efficiently make a diagnosis without just replacing the cheapest parts first? It's possible there is absolutely no linkage between the slow power steering leak and the noise, or they may be directly linked.
