- Thread starter
- #21
You might be right. Wow..good call. I will take somemore pictures tonight. When I removed my carb a few months ago the vacuum passage bolt I think they call it was missing out of the carb. It is the one that you screw into the bottom straight up to the carb body. I am positive it was missing when I removed my orginal carb. THe bolt I found was a flat head screw and I will check tonight to see if it was hollow.
Thanks Jim
I will try and take the bolt out of my new rebuilt carb to compare it to or if anyone has a pic of this bolt can they post it.
Thanks Jim
FJ40Jim said:Pictures are kinda fuzzy, but that looks like the carb throttlebody to mainbody screw. It is a hollow machine screw, 6x1.00mm, goes up into the bottom of the carb. it could fall out of the carb if it was loose. Has the carb ever been off the truck?
The bent pushrod came about when the piston was approaching TDC on the exhaust stroke and the bolt got between the piston & the still open exhaust valve.
It definitely has not been rattling around the cylinder for 10 years. a foreign object that size will destroy things in a matter seconds at 2500RPM. It could have been laying underneath the carb for some time, then finally got out of the depression under the carb and worked it's way up to the intake port.
