thebovees
Driving Cruisers since '67
'94 FZJ80: The speedometer needle has started bouncing significantly making so I cannot use the cruise control. Wondering if it is the sensor or, maybe, the corrector I added to compensate for the larger tires.
I checked the wiring diagrams and found that the speedo transducer goes directly to the cluster and the speedometer then to the engine control, the transmission control and the cruise control together.Well the cruise control is independent of the cluster, so the one thing you can say for sure is it's not the cluster. Either the corrector or the sensor could be a culprit. Dodgy wiring is also possible. The speed signal is just a square wave. As the gear turns inside the transfer case, it switches the signal from off to on and off again. The pulse rate determines the speed. The needle "bouncing" is reflecting what's going on with the signal itself, which is that it's getting stuck either on or off for periods of time. An oscilloscope is the right way to "read" the signal and know exactly what's going on, but you don't need one for this. It's a simple circuit.
I'd suggest removing your corrector. See what happens. If it's fixed, look carefully at it, see if it's a connection problem or if the corrector is junk. If it still doesn't work without the corrector, leave it out and keep on chasing. A multimeter will be required from this point. I'd verify wiring first, then look closely at the sensor. They can fail, was a frequent problem with Hilux models of the same era, although the speedo sticking on 0 was the more common symptom there.
