Speedi Sleeve PN or Size?
Franktown, CO
Guys,
I still need some help: I checked the Speedi-Sleeve sizing chart. They have a sleeve that will fit a shaft size of 98.37mm to 98.53mm. The next size up is 99.95mm to 100.10.
According to Poser's measurement I need 99.53mm so the first one is too small and the next size up is too big Any suggestions? Will the first one expand enough if I heat it to fit? Can I use high strength thread locker to cement the larger one in place so that it will stay correctly?
I will go measure a crankshaft....
3.918"
99.53mm
Thanks Poser!
Dang, next problem: I checked the Speedi-Sleeve sizing chart. They have a sleeve that will fit a shaft size of 98.37mm to 98.53mm. The next size up is 99.95mm to 100.10.
According to Poser's measurement I need 99.53mm so the first one is too small and the next size up is too big :crybaby: Any suggestions?
