spaaring perches?
The Sunshine State
ok for a spring over on a fj60 can i just use the spring perches that are already on the front or should i weld new spring perches on or can i just the ones that already there but can i still use the stock u bolts or do i need longer ones? i found these on jt outfitters http://jtoutfitters.com/product/MRG6280 they seem good to me i just need to know if i need two or 4,, 2 would be bettter cause it is only 20 and not 40 bucks.... lol
yeppers...dodge truck perches, like $14 for a box, 2 per box. Don't order 4 of that number or you'll have lotso extras!
so i only need two for the back and just use the ones that are already on the front axle???? ill figure this sh*t out someday
IMO, it's way easier to trim up the dodge perches for use all around than to salvage the stockers. Perches must be on top, cut the stockers off the bottom for clearance, save the "u-bolt-alignment-plate" to tack on the bottom too.
