Somedays the windshield, somedays the bug!
fj80toyman
...One Landcruiser at a time
So. California
A couple of weeks ago, several of us put new springs on 3 trucks. I decided to do only the springs but during the swap of the front springs, it was apparent that I was going to need new shocks. Ordered some up from Slee along with new Frame-to-Axle SS brake lines.
After a long trip from Colorado (Co->Las Vegas-> Ontario, Ca -> Las Vegas -> SLC -> Las Vegas -> Ontario -> Torrance) and a week later, the new shocks (N73L) arrived. I was so anxious to get them on it took me only 30 minutes to swap them out tonight.
During the rear spring swap, I had also broken a lower shock mounting bolt off. Since then, I could only fit in an hour every day but it took me 3 days to get that broken sucker out of there.
Now a few thoughts on using an EZ-Out
- Only use one if you're 99% confident that the bolt will move with light to moderate torque
- Pay attention to the drill size according to the ez-out size - you don't want the ez-out to go too far into the hole.
- When you're applying torque and you hear the very slight sound of cracking (sounds like pouring water over ice in a glass) - STOP!! You're done. The ez-out now has very small cracks that have significantly weakened the tool. The next application of force is going to break it off.
- Drilling a broken ez-out with a normal drill bit is useless, but I had to try anyway. Ruined only one drill bit this time before I gave up.
Well at the end of it all, I got the broken EZ-Out out by cutting a slot in it and using the air ratchet with an impact bit and basically vibrated it out.
I drilled, tapped and ran in a heli-coil. Hopefully good as new.
The good part is the front shocks went on so easy. That was to make up in some way for the grief the rear shock gave me.
Next is to get the brake lines on and replace the Caster bushings. It never ends.
Thanks for listening.
WoW, what a drag. I hate EZ-out type tools sometimes they work... but I normally I try not to brake stuff :flipoff2:
Ha Ha, No but s**t happens to the best of us.
Wow, sorry to hear that bolt gave you so much trouble! Bummer, but feels good to have it out I'm sure :D
By the way, I decided not to run the OME bushings and instead I have LandTank's caster plates on the way. Looking forward to a nice ride and gaining a little more lift out of the front. I'll let you know how it goes.
Caster plates may be the way to go. Let me know how those go and what the result is, I may be interested to go that route too. I'm not looking forward to pulling those front arms off, let alone pressing those bushings out.
Does give me a good excuse to buy another tool though :D Don't have space for a 20 ton press though.
You can always "store" it at my house....I would gladly take good care of your press....seriously Dan if you need any help give me a shout...
I have a press at my shop that any of you are more than welcome to use if you want.
Also, if you are planning on "a little more" than on OME or a J spring supplement I would definitely reccomend the plates over the bushings. My .02
