I started doing the electrical on my truck, but the old wiring harness is too damaged by the previous owner that it would be stupid putting it back into my truck.
So I am planning to take the stock wiring harness apart and only use the thick wires since they are ok (starter, glow plugs,...)
I've been having some trouble with my glow plug relay (sometimes 24 volt output, sometimes 7 volt, sometimes no volt) I was thinking to swap this out with a regular aftermarket relay, but I have no idea how many amps this should be, anyone got an idea?
Next problem is fusible links, there are none in the harness right now, and I would like them back for security in case of a major electrical problem. My plan is to put in Maxi fuses in the harness instead of fusible links, but again I do not know the amps of the fusble links, anyone got an idea?
For the smaller stuff (lighting, heating, windshield wipers,...) I'm planning on using relays too, now can 12 v relays be used in a 24 volt system (12v are easily be found here and are dirt cheap)?
Thanks for your time!
