- Joined
- May 24, 2015
- Threads
- 32
- Messages
- 359
Hi.
I am in the middle of rebuilding a '85 axle and I have a question regarding getting a heavier pre-load out of my knuckles.
As far as I know my axle is UN-molested and when I took my axle apart there was a .039" shim on the top, bottom, left and right. To my understanding, the bottom shim centers the knuckle and the top shim sets the pre-load.
I have read countless times of people saying anything that is done to the top must be accounted for in the bottom, and vice versa. To me that doesn't make sense. If the bottom shim centers the knuckle, then that shim would stay constant and the only variable in shimming the knuckle would be the top shim: thinner for more pre-load, thicker for less pre-load. If the bottom centers the knuckle and I take .010" off the top to get more pre-load and add it to the bottom, that would then put the bottom off center by .010" and not change the pre-load because there would be the same shim thickness overall.
I didn't measure the knuckle break free pull load before I took it apart but hypothetically say I throw it all back together and with the .039" shims all around I get a 8lb pull. Say I wanted a 14lb pull. Can I shim down the top until I get a 14lb pull without touching the bottom? I don't have a knuckle SST, but if I did and if the bottom one does in fact center the knuckle and the top loads the knuckle, that would mean if I took a measurement at 8lbs with the tool, the bottom shim would calculate out to .039" and the top would calculate out to .039". And if say I set the pre-load to 15lbs with the tool, the bottom would still calculate out to .039" and the top shim calculation would be less than what it was for the 8lb pull. Is this making sense?
