- Location
- United States
Yes, that is right, this is a very efficient radiator which can be coupled with a Mark VIII fan. I ran it this way for several years. But now am adding A/C and there is not enough room for it all, so I'm making changes.
Radiator is manufactured By Custom Aluminum Radiators, (McCulloch Fabricating, Inc. Specializing in Aluminum Radiators for Racing & Custom Applications) Bryan knows how to delete heat! You just have to move lots of air, which the Mark VIII does quite well!
Now throw in a Delta Current Controls fan controller (Welcome to Delta Current Control) and you set it and forget it. It worked that well for me. The controller is mounted right in the shroud, upper right hand side.
Moves lots of air when it has to and not so much when it doesn't..very consistent coolant temperature regulation and no big hit to your electrical system like a relay would do. I really wanted to keep this, but there just isn't enough room fore/aft to make it fit with an AC condenser out front.
Located in Boise, Idaho and willing to ship and/or separate the pieces if necessary.
Asking $225.00 for the lot and you pick up the shipping tab. This does not include the radiator "U" frame, you will have to use your own, but it is a dead simple mount as you can see in the pics.
PM me if interested.
Cheers!
Cheers!
