EXTERIOR :
ARB non winch front bumper
OME Suspension Lift
LT315/75R16 BFG KO2's X 5 (Approx. 6K miles) Spare never down
Shaved rear mudflaps
Factory hitch
Running boards delete
INTERIOR :
Custom fit driver and passenger seat covers
Dash mat
Steering wheel cover
LED lighting
Dual LCP Puma Mounts
On board PUMA air compressor W/4 ga. wire, Anderson plug, Blue Sea 70 amp breaker +
Jumper set up w/Anderson plug to use in another vehicle
Landtank seat extender, awesome extra 2" ( that's what she said )
Window tinting ( thru CBT )
3rd row seats w/ seat belts - ( not installed )
Attic Rack - ( not installed )
MECHANICAL : Work done by Camelback Toyota at 191K
New Crank seal and Oil pump front cover seal
New Drive belts
New Upper and Lower control arm bushings
New Rear Radius Arm and Lateral control arm bushings
New Factory front castor control bushings and SLEE Castor correction plates
New Extensionhousing output seal on T - case and speedo O - ring
New Radiator hoses, Firewall hoses and Heater hoses
Brake and Power Steering flush
Used Master Power window switch ...
New Hood Supports- Hood Support Depot
New Battery 10/18 - Walmart
Arizona truck born and raised, Runs great, clear coat is crap, has some dings and desert pinstriping, rear hatch lock key only, mirrors wobble.
IMHO for a 23 year old rig its a solid 20 footer. Life forcing sale, would like to replace it with a 06 or 07 stock Landcruiser. Asking $9500.00
OME Suspension Lift
Factory hitch
INTERIOR :
Dash mat
LED lighting
New Drive belts
