Wanted SoCal Stock wheels for 1979 FJ40
Monrovia, CA
Looking for 5 stock 15 inch wheels that have clips for hubcaps (disk brakes up front). I am in Southern California and can pick up if local.
toyota sells the original steelies that are welded instead of riveted, the riveted ones didn't work with my disc brakes. It is an option.
got oem toyota parts solution for your stelie disc brake issue
assuming its caliper to inside RIm contact ?
or .........
U also MUST Verify U indeed have factory FJ40 correct part# calipers
NOT Pickup , , truck , 4runner or Later land cruiser ones All have & with with bigger pistons and profiles
and do bolt right up in many cases
some GETTO re-builders like pep Boyz , will Mix up all the cores based on Bolt patters not other critical details
- This in one of many reasons why : RE-Manufactured Toyota parts Must be returned in there RED & Black original box
Also , Be a factory Toyota part ID's by the Parts dept's dude fellow
Toyota corporate was very strict back in my dealership days , and never made a exception to the rule , OEM Toyota calipers have a complex set of casting stamps and Logos from japan
I Will see if i still have my late 199,s early 2000's Core ID , and Picture Book Identification guide .........
