For Sale SoCal 1997.5 Mitsubishi Delica l400 space gear
So we have decided to put are 1997.5 Mitsubishi Delica space gear up for sell. It is the face lift version so it has the better looking front end. The van has the 6g72 V6 engine . This motor is a 3.0l that comes out in the montero so parts are easier to find in your local parts store. It is automatic transmission with a transfer case that lets you drive it in 2wd , awd, and 4wd with center locking transfer case. This vans are very comfortable and capable of great off road vehicles. It has working cold air conditioning and rear seats that are able to hang up for more storage, as well as power fold out and fold in passenger side steps. The van has 125,XXX Kilometers and a lot of maintenance has been done so that there is no surprises on long trips.
Stuff that has been done;
Timing belt
Water pump
Water pump housing
Timing idler pulleys
Timing tensinor
Camshaft and crankshaft seals
Harmonic balancer bolt
Thermostat
Clutch fan bearing
Power steering tensioner bearing
Air conditioning tensioner bearing
Alternator tensioner bearing
Accessories belts,all 3
Spark plugs
Pcv
Intake manifold gasket
Radiator 3 row(very rare,expensive)
Upper and lower silicone radiator hoses
Heater 3 way connects(metal)
Hoses from engine to rear heater
Hoses from engine to front heat
Hoses from reservoir to engine
Coolant reservoir
Fuel filter
Air conditioning seals from compressor
Air conditioning seals from condenser
Air conditioning Freon
Alternator
Transmission flush
Transfer case service
Rear differential service
Front differential service
Oil change
All this stuff was done so if we wanted to take a long trip we would feel confident in the vehicle. We have own delicas with 2.4l and 2.8l but in my opinion the 3.0l has the right amount of power and the parts are more available to maintain. The van is titled and register in Montana. We are asking 13,500 and no trades we are just trying to get what we’re in it. 951.322.08nine three.
