RLMS
Supporting Vendor
- Joined
- Sep 19, 2007
- Threads
- 147
- Messages
- 1,530
- Location
- Colo Spgs Colorado
- Website
- www.redlinelandcruisers.com
We have in stock, Sniper 2F Throttle kits updated. Newest version is here to stay awhile!
Three separate items; manifold side, cable and firewall side.
Both brackets use factory holes, so no drilling is required.
Please call us for more info or visit our website (links above in red to each item).
Red Line Holley Sniper Firewall Throttle Cable Adapter Bracket – FJ40 Land Cruiser
The Red Line Firewall Throttle Cable Adapter Bracket is available for 1973 – Oct’1979 40-Series Toyota Land Cruisers. The Firewall Throttle Cable Bracket is water jet cut with 5052 aluminum, anodized black and locates the throttle cable clevis directly to the firewall. This bracket bolts directly to the firewall using OEM holes with included new hardware.
Red Line Holley Sniper Throttle Cable Manifold Bracket 2F Kit – FJ40 Land Cruiser
The Red Line Manifold Throttle Cable Manifold Bracket 2F Kit bolts directly to 2F manifolds to locate and secure the throttle cable. This 5052 aluminum water jet cut plate is anodized black for corrosion protection. The brackets slotted mounting holes allow throttle cable position adjustment off of the Sniper rotation barrel, allowing smooth throttle cable operation and pedal feel. On the manifold side, the bracket includes a curved slot allowing fine tuning, if needed. Comes with hardware.
Lokar Midnight Series 36″ Throttle Cable
This is the throttle cable you want to use when doing your Holley Sniper 2F upgrade. The cable is adjustable for precise throttle control and fitment made with a stainless inner wire and glides in a PTFE inner liner for smooth throttle feel and “self-lubrication” / “no-bind” cable operation. The exterior is designed with a specially extruded liner for extended life of the cable – not to be confused with ordinary braided brake hose. Comes equipped with aluminum fittings and aluminum ferrules to eliminate fraying. Clevis is designed without cotter pins or set screws. Kits complete with installation instructions. These cables are proudly made in the USA by Lokar Performance Products.
