hey guys,
i was burping bertha for the second time this week and i noticed a burning smell but saw no obvious smoke. upon further inspection from various angles, I noticed that there in fact was a very light trail of smoke coming from behind the valve cover where it is closest to the firewall. i am guessing it is burning oil.
this is the deal: took bertha to toyota for a radiator recore after noticing redline heat readings and coolant leaks. re-cored radiator installed with new hoses and new overflow tank, (which PO removed,) new t-stat installed and the valves were adjusted.
started her up at toyota and she died right there in the lot. got her started on second try and her idle rpms are at 500, they said she had a vacuum problem due to cracked intake boots and now also has a rear main seal leak as well as some kind of side panel oil leak. New boots are now installed and she is still rough idling between 500 - 1000 and sporadically dying on us and she still redlines on big hills and now smells like hell with no obvious smoke (although there is a little if the hood is up and your head is in there). i noticed something, oil or water?, leaking sporadically onto one of the down pipes from the manifold and causing smoke, but there is smoke from the head/firewall area even when that moisture is not there. i have not fixed any of the oil leaks because we are broke and i suspect there is burning oil somewhere on this stuck pig. this work was done a month ago and we have been stressing about what to do since we cannot afford another vehicle and have invested a medium fortune in this money pit that may or may not now need a new head.
from reading various threads, i was gonna go and order a new FPR , fan clutch and Tstat but they will be pricey right?? i do not have an fsm but if you can describe things or tell me where and what to look for i can find them.
if there is anything else you guys can think of then let me know. we really can't afford to drop another 1000 now.
we just bought our first home and our cruiser is killing us. we are ready to junk her but we need her to run so we can work. i have been burping her as a last ditch effort to get her to run cooler but now the smoke and stench has begun and I DO NOT KNOW WHAT TO DO...PLEASE HELP!!!
you have been so helpful thus far and i thank you all for making this forum where morons like me can get info and get inspired. We need desperately for this truck to make it through the winter so any and all suggestions will be considered seriously.
