Ok, heres the problem. I replaced my shot vacuum solenoids with mac valves, which are very sano looking and work well. My problem is that it takes several minutes for the 4wd light to come on, although it turns off right away. My hose situation is kinda ghetto right now, i didnt have enough hose on the truck to work and my local parts store didnt have hose the size i needed (although im gonna go look again today) so right now there are sections of 1/4 inch rubber hose mated up to the stock small hoses that are stock. My question is, could the extra volume of air be causeing the slowness? I figure that may be an issue, but im also conserned about the vacuum diapraghm itself. There is definitly plenty of vacuum from the manifold (aka that line isnt plugged), and im gonna replace the hoses tonight if i can and see if that helps. Also, i figured i could test the lower hoses that run to the hard lines for air tightness (well, all of them i guess) with my vacuum pump and also see if the tcase engages faster with vacuum direct from the hand pump. If i do this, how much vacuum should i apply to get it to actuate the shift collar? 10 lbs? And if it still is really slow, how do i go about removing/troubleshooting the vacuum shifter assembly? Any help would be appreciated as usual.
Matt
Matt
