Slow Power Side Mirror Fix.
After so many tries to fix the issue with side mirror, finally discovered one of the motor was weak. adjusting the mirror.
so i took it apart to clean and re-grease the motors, check the mount screws hoping to fix the issue with shaky mirror on the highway or fix auto dip issue.
anyway, the simple fix for the motor is to soak it in " contact cleaner" for 30 mins and 80% of the debris will be removed. that accured to me when i couldn't open the DC motor. you can get it 100% back if you open the motor shell and sand some of the carbon there. but for now this helps a lot.
Got an similar issue with my Passenger mirror on my 2002 LX.
Sometimes it won't move up/down and I have to force it slightly and then it will move.
Thinking about disabling the automatic movement when I shift into Reverse.
well that i think it manufacture issue i read about (TSB).
