SOLD Sioux Falls, SD: 1998, Toyota, 4runner
Year
1998
  1. 4Runner
Mileage
243906
Color
Black
Outside Link
https://www.facebook.com/marketplace/item/408417936814980
Finally selling my 4runner to pursue other projects.
1998 Toyota 4runner 3.4l v6 5 speed manual transmission asking $12,500 or best offer
Mods include:
Engine and Mechanical
-Regeared to 4.88 w/ front and rear arb air locker (By ECGS)
-Tundra 231mm front caliber upgrade with slotted rotors
-Stainless brake line
-Clutch upgraded to marlin crawler HD about 1,000 miles ago
-ARP extended lug studs on front wheel hub
-Aluminum 3 core radiator
-ARB air compressor with detachable airline
Bumpers and Armor
-Front ARB bumper w/ warn m8000 winch and rigid cube lights
-4xinnovations rear bumper with swing out tire carrier, 2 jerry can holder, folding table, high-lift mount tab, and rigid reverse lights (rear poly body mounts)
-Savage offroad full underbody skid plates
Suspension and Tires
-Old Man Emu 3in suspension lift
-33in Mickey Thompson ATZ tires (44,000 miles on them)
-Level 8 Strike 6 Wheels
Interior
-Toyota Fog lamp switches for front and rear lights
-Ashtray delete for cobra cb unit
-JVC unit with Bluetooth and mic
-Tool holder/sleep platform (the back seats can be folded down to allow the sleeper platform to be fully extended)
-Dashcam wired in behind rearview mirror
Maintenance
-Oil change every 3-5 thousand with Mobil 1 5w-30 high mileage and toyota oil filter
-Front and rear gear oil changed 2 years go (about 30,000 miles ago)
-Coolant toyota brand red (3 years ago)
-MT fluid redline MT-90 (3 years ago)
-Timing belt (3 years ago 203,000mileage)
-Serpentine belts (3 years ago 203,000mileage)
-Spark plugs NGK copper core (3 years ago)
-Water pump and thermostat (3 years ago)
-Alternator (3 years ago)
-Valve cover gaskets (3 years ago) When valve covers were off no sludge was found and everything else looked normal
-Clutch fluid (1 year ago)
-CV axles changed (2 years ago) used napa axles have receipts for them aswell
-Brake line bled (2 years ago)
-Inner and outer tie rod changed (8 months ago)
Other
-Everything mechanically runs great, heater and a/c work, does have small dings but nothing crazy, worst spot of rust is on rear rockers, has mainly surface rust on frame but nothing too bad (can take more pictures if wanted), One jerry can latch is beat up from a trip still latches and locks. I'll throw in spare cv axle, timing belt, serpentine belts, spare clutch slave, 6 toyota oem oil filters, arb quick detach air hose, spare arb locker air line with fittings, spare relays and fuses. CB radio antenna is a 3ft firestik. Deleted the radio antenna and removed cruise control to fit arb compressor. I'll include the cruise control unit in case you want to reinstall. Any questions feel free to ask.
