I have a Canadian 3b, I am in the process of installing a turbo, I have replaced the original housing (oil filter faced up) that the oil filter spins onto, with a downwards facing one, which was taken off a used truck.
Prior to installation I cleaned both mating surfaces and used a new toyota paper gasket. When I started it up I got an oil leak dead center between the two top bolts, bolts are tight and I don't want to risk over torquing and possibly snapping something.
If I take it apart and remove the paper gasket, clean and reassemble using the proper silicone only, and in moderation, will this suffice or does it have to be a paper gasket only in this application?
Or am I just worried about nothing?
