I did a search and couldn't find info on it, but isn't there a common short in the guage cluster? Something is grounding out in mine and causing trouble all of a sudden. When I turn on the ignition, the BRAKE light comes on (doesn't matter if the e-brake is on or not) and once started the light goes out at higher revs but at idle, its on sort of dim and gets a little brighter as the RPMs go up, then goes out. When I pull the fuse for the guages, the ground problem goes away (put the fuse back in, and the problem is back) - also, when the head lights are on, it makes the alt moan, but the amp meter reads normal.
Where would I be getting reverse polarity in any of the guages? All of the wiring is in good shape back there - as is most of the wiring throughout the truck. The only other weird thing that crops up is that I can faintly hear the seatbelt buzzer (which I usually cannot, when things are good)
Any ideas?
Any ideas?
