- Joined
- Dec 30, 2012
- Threads
- 3
- Messages
- 12
Hi all,
I am having some brake issues with my 1999 HZJ75 with 240.000 km.
Since a few weeks I am having seriously bad brakes: the pedal is hard and there is no brake power. I have read about it and try to find the best solution without making unnecessary expensive replacements!
Some weeks prior to the issue I replaced my front brake discs and replaced the pads which were still fine.
After I went to the technical control, after which the issue occurd. At first I thought one of the techniciens might have messed around with something, but I highly doubt this.
I have conducted the following tests:
- When the engine is turned off I depress the brake pedal, when starting the engine, the pedal goes down (not as much as before, but it goes down)
- After having the engine on for a while, I turn it off with the pedal pressed. The pedal does not move down significantly (when pressing it I did have the impression there was a tiny bit of move in it (like 1 or 2 mm), but I think this was more because I was focussing on it)
- When pressing the brake I do not notice any difference in rpms when running idle, nor do I hear a real sounds coming from the brake pedal.
- In the past I did notice some blowing noise when changing of gear (no idea if this is related)
So I started to check the issue and started at the rear drums. Who knows that after 240.000 km they are worn and that causes me to have bad breaks. Well it turns out they are okay. To my surprise I saw that my pads are in near perfect condition after being on for 60.000 km!! My susprision is reltated to the LSPV, which hasn't been amended after the car got an OME lift kit of 7cm/3 inches. Anybody can confirm this?
So having noticed that the rear brakes are fine I will do the following checks:
- Bleed brakes and LSPV to ensure no air is in the lines (okay, this is not really related to my symptoms but doesn't hurt I think)
- Check the tubing going to the Brake boosters and verify if there is a vacuum which gets stronger when increasing the rpms while also checking on cracks
- Check the calipers, maybe one of them is seized after putting the new discs (mine where at 16mm when they should be replaced at 19mm), maybe the large difference makes them to seize?
Do you think something else should be checked? Maybe the vacuum pump itself? I am a bit worried not to find the issue and to replace parts which should't be replaced yet. I understood that the brake booster is expensive and that failure is rare. I assume the same applies to the vacuum pump?
Would love to hear your input!
Thanks!
Thanks!
