Sheet metal slip roller?
Colorado Springs, CO
Anybody have one I could run a piece of steel through? For the heat shield around my catalytic converter. Else I'll have to do it the hard way.
Let's see what @DangerNoodle says...he has done some sheet metal work (observed on his build thread).
I don't have much sheet metal stuff unfortunately. You could do some geometic stuff with a break, but I guess that really depends on what you are looking for. Maybe call Metal Products LLC in the springs and see what they can do for you. I had them do a lot of my more complex pieces that I need to have made in 4' sections. They are a full functioning shop and will make whatever you draw up, if it is possible.
Here's what I came up with. Not the prettiest, but it should do the job. Just hope the exhaust doesn't rattle against it - stuff is pretty tight.
1/8" x 3/4" steel bent to shape with an HF ring roller. Then bent the sheet metal around it with clamps and riveted it. Stainless steel on the inside, aluminum on the outside.
Similar threads
