I run a center limit strap on my rig with the 4-link and the 1/4 ellip packs. When one tire fully squashes the fender, the opposite tire can only fall away so far before the limit stops it. Probably less than 2" loose at ride height too, so it limits both tires falling away very well, and helps on steep downhills when you don't want it to unload too easily.
My only concern would be the balance...in your Tellico shot (I knew I'd been on that trail! lol), it appears like your front isn't doing much while the rear takes all the flex. In that specific photo, it works, since the front is on a relatively level spot, but if you were taking the front up at an angle, I'd be concerned that the front frame would remain level with the axle and tip the rig way over, versus compressing the front hard.
However, no two wheelin rigs and drivers are the same, so it may work great for you! (which, given the pic, it appears to!)
