Its been about seven months since I dropped a 6.2 diesel in my cruiser, and for the past month whenever I drive around 45-55 mph it seems that the whole drivetrain starts shaking like crazy. Its driving me nuts. I already took my driveshaft to be rebalanced, replaced my trans mount, and neither made a difference. Its also strange that if I go faster than 55 it stops and drives fine. I'm totally confused and just hoping that its not my transfer case. Any suggestions or advice would be greatly appreciated.
Your problem and my problem are the same. Good luck I have replaced my entire rear end and rebuilt my drive shaft. And it is still making noise. I suggest that you try and drive truck without rear drive shaft on and see if it is still making that noise. You may have a issue in your tranmission.
I have not checked the rear end, but testing it in front wheel drive is a good idea. I sure hope that its not my trans but I would like a solution to both of our problems soon.
If the tranny/transfer aren't making any noise thn it has to be a rotating assy, rear pinion would sound horrible, Been wheeling hard lately to where you may have bent an axle? Checked the U-Bolts?
Yeah that sounds bad to me too, but I haven't been wheeling in a while and I just checked the u-bolts. So right now I really don't know what to do. I'm almost thinking of asking the the smog station I used to go to to let me run my cruiser on their rollers and maybe see whats going on.
I guess I'll just wait till I have some time to go through things and maybe take it to the smog guy to have a look, but I doubt I'll be driving it soon with diesel prices at $4.79 a gallon.
drove my truck after sitting for about two years for motor swap and had the same problem 45-55 shakes like its gonna fall apart. stole a set of tires off my brothers truck and not a shake at all. still havent got the tires balanced just too lazy just know its there and got used too it.
