I need to get an inch or so on my pig, the 33x9.5 tires are really close. I don't have the money/skills to buy new springs and fab mounts since noone makes 55 springs anymore. SOA is way more height than I want. So I figure a little extension on the shackles is cheap, easy and modest. I know longer shackles aren't usually the preferred way to gain height. What are the downsides to doing this? I've never done one of these before, so below is my thought process--please let me know if I'm missing anything.
I also noticed that stock, the front shackles are a different length than the back, specter claims 2.5" front and 3.5" rear, which looks rights (can't find my tape measure.) So I figure I'll try to keep the same disparity, i.e. about an inch longer in the rear. I figure I'll go with the SOR Extreme Shackles:
Specter Off-Road Land Cruiser Parts - 288-92 Extreme Shackles
I figure, a 6" in the rear and a 5.25" in the front should net a 1.25" lift.
To do it right, the shackles are greasable,but I shoud get 4 greasable mounting pins, so the whole thing can be lubed. 24 new bushings should round things off.
Next SOR says I need shims to correct the caster, so a set of 4 degree shims front and rear, and longer centering pins. Total cost should be (with SOR discount):
Shackles (x2): $164.90
Shackle Pin (x4): $118.96
Bushings (x24): $42.24
Shims (x2): $34.00
Centering Pins (x2): $18.70
Total: $378.80
That should cover everything, and doing it right. Any thoughts?
Geof
Shims (x2): $34.00
Total: $378.80
Geof
