- Vehicle Model
- 80 Series
- Location
- California United States
This is the ideal setup if you’re looking to rotate your catalytic converter for better clearance under the rig. I’m selling a MagnaFlow California Grade CARB-Compliant Direct-Fit Catalytic Converter (Part #447103) with CARB Executive Order D-193-103. It’s been used for 20,000 miles and was ceramic coated for added durability.
Retails for $850 before coating—letting it go for $400.
"MagnaFlow California Grade CARB Compliant Direct-Fit Catalytic Converter 447103 helps keep the check engine light off. DIY installation is easy with the proper tools (no cutting or welding required). With features including mandrel-bent tubing to eliminate flow restrictions and stainless steel construction to resist corrosion, you can have confidence in the quality of this catalytic converter."
