Serpentine belt swap - how far are you all going? (1 Viewer)
LINUS
Waiting for the Great Pumpkin
PNW - WA
Title says it all - truck is a ‘12 w 80K - 5.7/3UR
changing belt on age, and tensioner b/c it just seems smart - just noticed the extra idler pulley on DS - anybody refreshing that too?
Tensioner was $80, belt shy $90 - just saw idle pulley, no clue $$ (dealer parts)
What parts are you all swapping?
personally i would do just the belt. the only time that i ever changed the tensioner or idlers was when the pulleys started to make noise or they were rusty and crusty and i couldnt wire wheel them clean, they dont really go bad all that often
YMMV - If the pulley bearings are quiet and tight - good to go. If the tensioner moves easy and doesn't have in/out slop - good to go.
However, if your rig has 200K+ - YES, replace away.
I replaced my 5.7 belt at 103K - no issues with bearings / tensioner found.
Good luck!
I’m just 80K - but it’s 12yo belt / everything is 80K/12yo - so I’m thinking the full bearings (tensioner & pulley) belt all real stealer parts.
Also betting coolant & t-stat are OE, so they both go.
Anything else I should look save spark plugs?
—— I’m trying to make the serpentine setup / coolant / plugs GTG for ~5yrs save a part failure down the line.
For my Tundra it’s age, not miles where things will fail.
I just need to keep up underhood rubber as I do short trips like 1st owner - critical hose in coolant system while drained & fresh red/pink goes in?
Heater core valve a issue before ~ 150K?
I know the 1FZ, but the 3UR/5.7 is a new animal for me.
PVC valve for sure. My was plugged at 103K. Cheap and easy to replace.
Clean T-body as well.
Carry a spare ignition coil.
Not much else on the 5.7 it is much more boring than the 1FZ! :)
Generic PCV or did you pony up for the real deal from dealership?
I’m calculated my total mileage annually & 40K more to the 120K range when the maintenance schedule has the tensioner & idler pulley & it’s easily 4 yrs away, so just ordered all 3 parts / do it all now - if the parts coming off are still good, oh well.
Not even worth keeping the old parts beyond ~6mo so I know all the new parts are flawless/bed in right.
120K is forever away on all new parts - like 2036. I don’t mind if the old ones coming off this weekend are like.
@LINUS the real deal from the dealership is like $9. Just be super careful installing it. My first one snapped off at the threads without any real effort once it bottomed out. It was an easy extraction with a large flat bladed screw driver but still. Time and money.
@LINUS the real deal from the dealership is like $9. Just be super careful installing it. My first one snapped off at the threads without any real effort…..
Ha, wish it was $9.
I had them reversed- $83.80 for belt, $96.71 for tensioner, $113.13 for idler pulley. 😵‍💫
According to receipt, all 3 were about 75% real price vs the “list” price.
List was roughly $360 , ballpark.
With tax, I was just over $300.
There was no $9 anything……..maybe the coffee for those in customer lounge :lol:
But I asked & hourly shop rate is $180, so there’s that too - might be higher/lower than your local dealer.
There’s 2 good vids on YT for the work, so straightforward IMO.
The key seemed to be to preload that tensioner w/ Allen wrench to hold compressed, belt is massaged into place after that.
@LINUS I was referring to the pcv valve.
Sounds like I’ll drop a few extree on the PCV valve - mine is old & a cheap part like that is a no-brainer next I hit the parts counter.
I’ll get a non-dealer shop to do coolant & t-stat done, but still do Carfax stamp/reports - sucks to buy that stamp or report, but IMO smart $$ long-term if I have ever to sell.
I H8 when people don’t follow up on things, so I did the :
Serpentine belt
Tensioner
Idler pulley
All had 81K / was ~12yr old.
The motor starts/idles far more quiet & runs down the road smoother like it was a new rig off the lot.
Doing all 3 parts is amazing how it was so smooth at idle & to ~3K RPM.
Plus, all are new/ esp the 12YO rubber serpentine.
Even at dealer prices, the result is worth it if you have older rigs - even w/ lower miles.
That’s just my opinion.
Change belt every 40-50k
Changer Tensioner, Idler, fan bearing bracket every 100k
Mine was a bit off as I have 81K on a 2012.
I did all 3 & the idler bearings were OK, but it did spin longer than a new one by a good amount, the tensioner was slightly better - but swapping all 3 @ 81K/12YO - starts and idles quiet as new, as it mostly should.
Really, doing all 3 on a 5.7 / 3UR is doing it right since it’s going to be 2026 before I hit 100K & as often as truck use is towing the boat, last I need is a failure in the serpentine belt dept while dragging the boat.
Now with all 3 done, I’m good for a long time there.
Fresh coolant & a new t-stat are next.
IDK miles, again doing mine on age & as much city/short trips as mine thermal cycles.
I just used a known brand from Rockauto, it was like $5. No issues with installation, hit YouTube for a how-to.
Will check - thanks for reminding me!
Since it’s really just a check valve, a pair of good gloves & lacquer thinner/acetone has always revived mine on the 80, but you’re right - that lil’ SOB if clogged can cause havoc.
