Seeking subwoofer replacement advice for 100 LC Series
California
I just replaced the OEM stereo system on my 2000 LC and need some advice on replacing or modifying the existing subwoofer in the quarter panel.
Music sounded pretty good from the front seats, but my passengers in the back said they just heard bass back there.
I sat in the back seat to hear what the music sounded like and was surprised. The second row speakers had low volume and no definition, and the sub woofer just sounded like mud. Playing with the bass and treble controls didn't really help.
I removed the OEM speakers and was really dissapointed. They were just 6.5 inch paper cone one way speakers and looked cheap. I think they're full range speakers but the definition that I heard from the front seat came from the small tweeters on front door jam.
The subwoofer hidden in the rear cargo back panel were two small 4" paper cone woofers built into a plastic ported housing. I'm sure they did this due to restriction of space, but 4" subwoofers seems very limiting.
I replaced the four speakers in the door panel with 6.5 inch composite 4 way speakers, and wanted to keep the OEM 6 CD changer head. (I had to cut out the old speakers and the back cage of their plastic frame to be able to mount the speakers on the existing frame.) However, I found that this even sounded worse. The deck just sends audio signals to the factory amp that's under the front passenger car seat, and that amp is greatly under powered. It was too weak to drive the new speakers and they sounded distorted.
That amp also seems to have crossovers built into it, so the front speakers had full range sound, the middle row speakers seemed to have only mid range, and the sub woofer in the back produced the muddy distorted low end.
I ended up replacing the OEM deck with a new one that playes CDs / MP3s and had a ton of other built in audio control features.
For the best value and best sound / features of the decks I listened to, I choose the Pioneer DEH-P7800MP deck ($330 list, $198 online) and two pair of Pioneer TS-A1680R speakers ($110 list, $58 online). The deck had ample juice to power all the speakers clearly and loudy. I played Alan Parson's "Eye In The Sky" and was thrilled to hear the crisp full sounds that I didn't hear before. The deck has great EQ built into it and I could also control how much sound went to which speaker. The sound was a great improvement over the factory system.
The only problem I have now is the factory two 4" subwoofers assembly in the back quarter panel. I wish I could put a bigger subwoofer in the quarter panel, but the subwoofer space is so small. I don't want to install any extra subwoofer cabinets because I want to keep the storage cargo area clear. I'd like to keep it looking as factory as possible.
I decided to bypassed the OEM amp and found an old Alpine 70 watt (35 per channel) amp in the garage. I installed it and had that drive the OEM subwoofer. This turned out to be a great improvement as well. It does not handle the super low end as well as I like, but for 4" speakers, the bass is full and tigher with the Alpine amp and not as muddy as before.
The deck has independant control for how much power and volume goes to the subwoofer, so I've been able to tailor the sound.
I was thinking of cutting out the two four inch speakers and replacing them with just one 6 X 9 speaker (the space is short and wide, so a 6 X 9 speaker may barely fit in the existing casing). I thought that this might be able to produce more punch in the low end and move more air, but I'm not sure if the casing is specifically designed to port just for 4 inch speakers.
Has anyone else gone through this yet, or have any thoughts on getting better bass sound without having to use up the cargo area space and still keeping it looking factory?
Alpine used to sell 6x9 dual coil subwoofer that might fit perfectly with spacer. They are only 60 watts so it might be Ok even with stock amp. The part number is 6191. They are pretty good but since the space are limited it would not sound as good as boxed subwoofer.
I took out my factory subwoofer enclosure and installed an Orion 4 channel amp w/ Audio Control 2sx crossover in its place. That seemed like the only place to put it. I also wired the amp to a switch next to the jack w/quick disconnects for the speaker box, so that I can turn it off and remove the speaker box. I think I’ll go with JL Audio when I’m ready to upgrade my factory speakers.
I like your 6x9 theory, but I don’t think you will have enough air space in the factory enclosure; the port probably won’t work as well either. I say go for it and I hope it works, if not let me know I have the old speaker box. Nothing ventured nothing gained.
Does the 98 LC have an external amp like the 99?
DMX
Dont you think the sound of your engine slinging mud everywhere would be a better sound! You should install that junk in your Honda Civic. Save your money for some real toys. ;p
I really love music.
Driving and listening to a full loud clean sounding music does something really good for my psyche. Can't explain it. Driving the LC is already an enjoying experience and to be surrounding in great sound only enhances it.
I'm not into the thump as much as I enjoy great full sounding bass. I've been playing with the Pioneer head unit and it's really great for adjusting what kind of sound goes where. It's actually sounding really good now after the adjustments.
I think I'm set for now as I think the only real option to enhance the bass is to put in a speaker box in the back. I want to keep it looking stock so I don't think I'll go that route.
Hi Kalin,
I just sent you an email regarding your Pioneer DEH-P7800MP deck ($330 list, $198 online)
WHERE DID YOU GET IT, I have been looking for weeks!!!
I like the sound of my Borla and MTRs. :D
Got a sound clip of your 100's borla?
Jeesh, Don't know what to make of this?
The amp was your biggest improvement, I would go bigger though. I had 2 6.5" cruch subwoofers in my 4runner and they really bumped, I am planing on installing them in My LC. Sorry I can't give any advise yet on the install, but in that size space I think that is the best way to go. They handle alot of power for there size. I wouldn't reccomend a 6x9, I think speakers should be round.
