Seam Sealing Day is Upon Us! (2 Viewers)
Virginia
Morning -
Great info all over this site regarding the rain gutter seam sealing job.
Question: how "high" does the seal have to be? I will be using the 3M self leveling product; some photos show it level with the side of the gutter?
Since no one answered yet, I’ll chime in.
Keep in mind I’m a newbie on the 60. :)
I don’t think it has to be that high as long as it’s over the seam where the top meets the gutter. As long as everything is covered should be good.
I will add, do make sure you have 2 tubes and take your time with it, but not too much time when you apply. I went too fast and had to come back cause it wasn’t covered and it doesn’t look that great in those spots.
Well... so far mostly good. Some overspray from the 2K primer despite what I thought was adequate masking.
I ran the tube of seam sealer dry as I rounded the rear corner headed into the driver side gutter! I thought one tube would pretty much do it... I have another being delivered tomorrow. Will that pose a problem - stopping and re-starting?
Also, if I want to thicken it up in some areas… can it be applied over itself (overnight cure first)?
