Progress...Reminds me...
I need a new fire extinguisher and washer fluid.
Found one in my NM garage.
Now I just need to plan a trip to NAPA.
Settle down now…
Can you still get Toyota Factory Air? That supply has probably run out by now right?I also still need to rotate the air in my tires.
Can't forget the spare...![]()
Did you renew your blinker subscription? Can’t run out of those on the trail.I also still need to rotate the air in my tires.
Last year's bottle got either all used up or somebody kept it, what an idea@Fyffer usually carries extra blinker fluid on the trail in case anybody’s stuck and needs it.
That's where it came from...Last year's bottle got either all used up or somebody kept it, what an idea![]()
I was about to say that you are going the wrong direction. By this point parts should be going back inView attachment 4150211Unfortunately @PeterTheBeater is out this year. Blew head gasket and YOLOing a Cummins swap.
Most important, a PeterTheBeater jr is coming in July and would be too young to travel to Colorado.
NA just chilling, going to pull the third todayAnxiety attack to the max!!
Is that a coolant filter on the firewall?View attachment 4150211Unfortunately @PeterTheBeater is out this year. Blew head gasket and YOLOing a Cummins swap.
Ya been running one for 6 yearsIs that a coolant filter on the firewall?
All nuts and bolts my friend. You'll be good as new in no time.Put in 2.5 hours
View attachment 4151896View attachment 4151897Unfortunately the end of the axle is stuck in there
Already dropped it off it American gear they did gear set on this diff 10 years ago and I’m happy with there work.
Should have it back by the end of the week.
Come check out this map of the Alpine Loop if you are at the Coloyota Expo. It could be yours as it will be part of the raffle/auction.
