Build Salted Pork fj55 family wagon build
I forgot about this but my brother and his Fiance found this vintage 1971 plate in an antique store back in October. Finally getting around to throwing it on the fj55. I worked on my isuzu pup some this morning but it is not going well. ever since the headgasket went its been one head ache after another. Its my white whale! currently the timing chain tensioner and a coolant leak are keeping me from running that truck again. unfortunutly I think I gotta pull the engine to replace the timimg chain tensioner on the isuzu... ugh. It is what it is and I will eventually pull the motor back out and do what I need to do.
After being frustrated by the isuzu, I started making some patch panels for the fj55. Iknow this corner is not going to ever look factory but it will be ok it will look good. I think this hand made panel turned out pretty well. Ill get it zapped in when my welder shows up.
lots of test fitting, bending, hammering and cutting to get this just right.
More trimming, and bending and its looking pretty good.
I still need to do some trimming before I weld it in but its looking good.
I also worked on a few spots on the cowl that started rusting out probably because the windshield gasket is kinda toast. Hoping to replace that this summer.
Nice patch panel. There is a certain artistry to making panels with compound curves. Looks great
Paint update - I have been testing paint colors to see what matches. I can tell you that pueblo brown is 100% not the color. I did just order T-451 Coronado Beige in a spray can. We will see if thats correct. I believe I red that on @roadstr6 s build. I think he told me that too.
My new Millermatic 142 and helmet should be here by Wednesday so thats fun! A new dad gift to myself. Speaking of - I will be leaving the island on Friday to be with my Wife while she gives birth to our first child. The baby is due the 22nd but I want to be there a little early. (if all goes to plan and she does not give birth beforehand.) Where I live you have to take a 2.5 hour car ferry to get here. So to play it safe people go to Morehead NC to give birth. Nobody has been born on Ocracoke since the 1970s. We will have a new cruiser head soon! I already have a fj55 onesie for the baby thanks to @SC-Cruiser.
Oh come on! Make history!!!
Maybe being an art teacher helps! thanks! I am hoping the passenger side goes as well.
hahaha Rachael is already off the island in New Bern staying with her parents. I would be ok with making history but the island doctor says otherwise....
Kinda what I was thinking.
Find a 40, 55, or 60 series front disc axle. 60 series will be more readily available than 40 series.
Grab the “outers” and graft them into your existing axle. Since you're in there, replace the bearings, pads, etc.
Do not bother with “bolt-on kits” that still use the factory drum brake knuckles, steering arms and wheel hubs.
Way more experienced people than me have deemed them "not worth the money".
Example: Georg at Valley Hybrids once said, "We’ve seen multiple failures and refuse to install these."
You made a good, well thought out decision based on "your" needs. I got by with a 110 volt Miller for many years. I thought about selling it when I got my bigger welders but, it's just too handy to get rid of. It's very portable and flux core isn't a problem in the wind. I still use it often.
I hope your new Miller is as trouble free as mine has been. Got it around 1986 or so.
I have a Millermatic 35 from the early 80s that is still going. Nearly all of the parts to rebuild them are still available, and there are occasionally FB marketplace finds to be had.
Let me know if 451 Coronado Beige works for you. I could never get a definitive answer, so I just did a custom color match.
Yep kinda what I decided that I should do it with toyota parts. I had talked to Kurt or sombody at cruiserteq a while back about what parts I would need. I Was going to start looking for a 60 series axle. but thats a future project because I have no qualms with my drums right now. just a leaky cylender on the passenger side. but then I realized I have a wheel cylinder that I might be able to use. I also have rebuild kits too from cruiseroutfitters that I forgot I had. so Might use that. or I might just buy new wheel cylenders. Just need to fix it untill I have enough money saved up to pretty much rebuild the front axle with brakes.
I will, I am curious too. Its really weird to me that the land cruiser community does not have a solid answer on this because I have asked and looked too. I guess its a more rare color? I have seen others though. Reminds me of Hot chocolate or chocolate milk in color.
I think thats what I am going to do to find a 220 v welder. I should get my new millermatic 142 on wednesday I am pretty excited for it!
Except Gail C is the best Doc ever, and could do it blind folded. But, she understands the "what if's" on the island, and like most things, better to err on the side of caution.
Congratulations to you guys 🤙
When I first got my Pig, in 1986, brake cylinder rebuild kits were cheap and easy to find at Napa. So I rebuilt everything and had great brakes. Had them balanced and tuned and could lock up 33s whenever I wanted. Made an impressive sound and worked better than a horn. I saw no need for disc brakes.
IIRC, the 55 rear wheel slave cylinders are slightly larger bore than the 40s, and rear shoes are slightly larger than 40s. Different part numbers. Double check me on that.
Get the special spoon brake adjusting tool from SOR, it really does work better than anything else. Put anti-seize on the threads of the adjusters and where the adjuster sits in the cylinder. Probably replace the brake hoses too.
ALready ahead of you on the brake spoon adjuster. I bought one from cityracer a couple of years ago. and good tips on the rear shoes. and I am big on antiseize.
alright I will try and rebuild the cylinders I think that will be the most economical for sure.
I actually have some actual cylinders laying around too from my fj40 too but I think that those wont work being the fj40 was a 64. The cylenders were almost new but I changed them out anyway.
Some updates. I asked the question about the fj55 rear window and how to get it to go up faster and I started to mess with it yesterday for a hot minute after work. And all of a sudden I got my key to roll it down (albeit slightly finicky) for the first time since I have owned the fj55. Thats a huge plus. I think there must be some bad contacts in there or somthing that needs cleaning because I can hear a solinoid or contacts or somthing clicking in there. some times it works sometimes it does not. either way I actually can see some hope with the rear window at least.
Got my hobart inventer series helmet yesterday and holy crap its so much better in terms of seeing than the eastwood helmet I had before. Probably because the lens is clean haha.
Yea, there are a few areas where the wiring can go 'bad' on the rear window.
-The connection strip in the back door
-the safety switch
-key contact
-the fuse breaker (auto reset) that will kick in if the motor binds
-the dash switch contact
did anyone say barn doors?!
-the safety switch
-key contact
Barn doors would be pretty cool. I am a big fan of the tailgate though. Just the ability to sit on the tailgate is nice. @Shyrock s new fj55 has barn doors and its super cool. I would love that. Also I have read that Australia got a tailgate version with a hand crank rear window Kinda like I have seen on old wagoneers or k5 blazers This would have been ideal for sure.
Going to go down the list of things I have checked from your list -
Connection strip - I have cleaned but I will say my fuse panel in the engine bay had a brake in it causing the headlights not to work. I found that the terminal for the headlight fuse did not have continuity. I could not see the brake. all worked after I replaced it. So I might buy a connection strip. I think they are the same part found in the fj40s. Looks the same.
the safety switch - I believe somebody already bypassed the safety switch. I will double check that.
Key contact - I for sure think this could use cleaning. I have never had it work till yesterday.
The fuse breaker - this does work. because it for will slow down going up enough for it just to stop.
the dash switch contact - dash switch works perfectly but I am always down to clean contacts.
When you’re ready to go disc front brakes or want to start collecting parts, we’ve laid out all the needs here on Mud:
Hell Yeah! thanks Kurt! Eventually I will go in this direction. Kinda hoping I will get to it this summer. I am going to keep this in my back pocket. Going to order some transfer case parts from you at some point soon too. The tcase is next on the list before discs. Pretty sure I am just going to buy one of your rebuild Kits.
