Rust behind left rear light (1 Viewer)
New Zealand
My Landcruiser BJ73 recently failed an inspection because the rear engine mounts were completely severed. I happily replaced them and was looking forward to rides without the engine rocking to the left and right when slowing down or accelerating. The engine had always been rocking a bit and I had thought this was caused by wear of the join between the drive shaft and the gear box, so this was a cheap fix. However, the Cruiser also failed on the registration plate lights. I thought this would be a matter of replacing the bulbs, but that wasn't the case. Something else was wrong, so I started to look for breaks in the wires. That's when I found a big rust hole behind the left rear light (see picture). And underneath the jack was about a litre of water with rusted nuts and bolts and other bits an pieces in it. I'm thinking of repairing the hole with glass fibre and epoxy, but how do I keep the water out? It seems to get in from behind the rear light. There's no weather seal, and there's no weather seal around the right rear light either. I looked in the workshop manual, online parts databases, but can't find weather seals for the rear lights. Are there not meant to be any weather seals? Is the water meant to just get in?
Hello,
Rear lights have a lip that is supposed to keep water and dust out. It does not.
You can apply a bead of sealant (automotive grade silicone such as windshield sealant) over the rear light lip and let it cure.
There is a cavity in the lower sill. Water that enters the rear quarter accumulates there, and can cause corrosion. In the lower part of the rear quarter, between the body and the fuel tank, there is a rubber plug. If you have water in the sill, take the plug out and let it drain.
Another source of leaks in a 73 Series is the sealant between the rear windows and the FRP top. In old age, the sealant lets water in, particularly to the lower sill. Check your rear windows for leaks and reapply sealant as necessary.
Last but not least, a layer of WD-40, silicone oil or cavity wax in the rear light well helps as well.
Hope this helps.
Juan
